Good day, I removed my seats to recover them and unhooked the positive battery cable first thing then without thinking closed my hood all the way down. I have a 2001 boxster base model. I tried taking the small cover off and applying positive to the little clip you pull out and nothing. I am afraid this will not work because the positive cable is off the battery. Any help would be great. Thanks Phil in Ohio.
Can you get at the manual release cable (if it's still there) that's tucked under the passenger(?) side wheelwell liner?
