1997 Boxster 2.5 Auto - right hand drive
I recently had a water leak inside the car which I have fixed
Trying to find it I played a hose onto the windscreen
The alarm got very wet
I locked the car and at 2 in the morning it kept going off
I removed it and put it in the garage
I have dried it out at home but when I fitted it today it just keeps going off
Will this re set or is it faulty
If I get another one is it 'plug and play' or do I need diagnostec equipment to re set it
Thanks Dave
That is the key - do a search here you may or may not be able to cleanup and recover the alarm control box.
Durametric, a PST2, or PIWIS tester will help find the exact fault(s) -- but the key is if there is corrosion and damage inside the alarm control box.
It is the alarm in the front with the siren not the box under the seat, that is ok
I have dried it out but it still goes off
Search for what ??
My question was will it re set or is it faulty
Can I fit a replacement by just pluging it in or do I need diagnostic equipment WHICH I DO NOT HAVE
If you did not open the alarm box and check for corrosion then you may well get an unwelcome surprise and get stranded somewhere when it fails.
When water gets inside operating electronics it can corrode connections and components. Many times the damage is not repairable.
Best find a shop that has one of the diagnostic tools I mentioned and see what fault codes come up.
If you end up having to replace the alarm control box you will need a shop with a Porsche PST2 or PIWIS tester. Re-programming the alarm control requires IPAS codes and all functional keys (along with their 40 digit unique id) to the car.
Sorry but this is not a simple task with the Porsche programming tool and the proper security codes.
You are talking about the red Siren in the front hood compartment aren't you ?
No I have not opened it yet but I will
If I get a second hand one does it need to be programed to the car or just fit it and work
QUOTE
So now please :-
The question is as above
If I get a second hand one is it plug and play
No I am talking about the alarm box under the seat.
Well I am not, please read my post correctly
The Siren -the red one -under the front hood - sealed and certainly very dry
it goes off on its own and does not stop even with the fob pressed, I have to take it off and wrap it in a blanket until it stops
Is it plug and play to replace it
Not being rude
I was never talking about the box under the seat, you did not read my post properly
I clearly said the alarm in the front, under the hood, the red one with the siren
I will get a second hand one and plug it in
