Hi Guys! Just a quick question: alignment shop says tie rods are frozen (locked up) so the rod won't move. is it necessary to loosen the nut on the inner tie rod to adjust the outer tie rods. I can't imagine what else would keep the rods from turning. I did a quick search for this but came up empty.
Thanks in advance for all the help!
Tim in Ft Worth
no, the inner portion is essentially just a ball and socket joint, so it spins freely.
if it were me, i would hit the threads that are visible with a wire wheel to clean are the rust and crap out.....then spray it with some liquid wrench and get on it with a big wrench.
the other option is disconnect the tie rod from the knuckle and try spinning the rod end off while holding the nut
