Does anybody know how to remove the knob as I have a new knob and gaiter I'd like to replace the old set with.
I tried pulling until i was blue in the face!
Not a big deal but Id like to know if anyone has the time to tell me .
Thanks in advance.
Two type of shift knobs (manual transmission).
The stock shift knob just pulls off - twisting helps but it will be tight. Do not hit yourself in the face.
Optional knobs have a hex set screw that holds them in place. Lift the boot up completely until you can see if there is a set screw - or not.
Pry up the leather shift boot. There is a retainer ring at the bottom on knob under the leather boot - twist it clockwise 90 degrees. Then pull up hard, careful not to hit yourself in the head or hit the rear view mirror.
