hi, i have a 996 . It has trouble starting. It will click and not wind. If i click it a few times it will start. its getting worse. But when it winds it sounds very healthy. I'm new to porsches. is this a common problem? do i need to change the starter?
Assuming the battery is good, these starters can and do stick in the solenoid . The can be rebuilt and replacement is a 20 minute job and can be done by the enthusiastic amateur or any workshop. Instructions here in the DIY from memory.
I would just plan on changing your starter. First make sure all your connections are clean and with no corrosion, including the ground strap (from engine to frame/battery to frame and don't forget the 12V + jumping post in the engine compartment). If problem persists, the starter solenoid is going bad. Had same problem, did all the obvious, finally gave in and replaced the starter...no more problems. You can get a new Bosch starter for $265. Replacement/Installation is a half-day job. No sense in just replacing the solenoid once you have it out...might as well just install a new starter at that point.
