If I cannot resolve my "no satellites" problem cost effectively I may consider fitting an after market sat/nav in my 2007 Carrera 4s - does anyone know of a good sat/nav with blue tooth that will integrate with the Bose audio system etc. without too much modification ?. I do not need the telephone facility.
Many thanks
Since the PCM 'talks' to the Bose Amp via the MOST Link (fiber optic) I think you'll be stuck w/ rewiring the speakers and sub-woofer the 'old fashioned way' . . . . hard wire, if & when you switch to an aftermarket unit (ie Alpine, Pioneer, etc).
There are plenty of DIY threads on the various Porsche forums (ie. 6 Speedonline, Renntech, etc) that might give you better insight.
