I just received my "Enthusiast" Durametric tool and immediately set about to clear PO301 fault. No problem there, but in doing the "short tests all modules" I got 2 hits, both information notices. I can't find these faults in the fault codes?
1. Alarm - 132, P/N 996 618 262 03, then a supplier number - 080504008003
2. ABS/PSM 5.3
P/N 590 996 618 14
Do we have a PET parts manual on line? I have no CEL's on the dash, so what does this mean? I didn't want to clear anything until I know more about what I'm doing, stay tuned, Film at eleven. The fun never stops...
CELs (or MIL) are emissions related faults and alarm and ABS are emissions faults.
PET will not do you any good for those faults - PET is a parts list.
We need the fault codes for those modules to help diagnose if there is a problem.
My usual advice is clear the faults and see if they come back - if they do then you have a likely real fault. A fault can be generated for something as simple as a power interruption (like when you change the vehicle battery).
Thanks Loren,
I know that the PET is a parts manual, I was thinking if I could match the P/N's given on the "information faults" then it might help to diagnosis the faults. I guess that might be a reach in as much there's not a reverse way of finding P/N's? OK, I've gone to Pelican Parts Catalog and found the following...
1. Is a thef control unit - http://www.pelicanparts.com/cgi-bin/ksearch/PEL_Search.cgi?SUPERCAT_FLAG=&make=&please_wait=N&forumid=&threadid=&command=DWsearch&command=DWsearch&REFINE=Y&FORUM_REFER=&SUPERCAT_FLAG=&make=&description=99661826203&x=39&y=11
2. P/N 590 996 618 14 - nothing comes up on the Pelican Parts Catalog.
I'll clear the faults as you suggest...
