I just installed a pair of Lloyd's front clear "Protector" floor mats. The car came with the heavy ribbed rubber mats, while they work well I thought they looked a little industrial. Plus they are very thick and w/ my size 13 shoes the clear Protector mats give a little more room around the pedals. I also removed the mounting clips and straps. You could see through the mats so the straps showed, plus the plastic end caps to the seat rails were really tight because the mats were under the nose of the rail caps. By getting rid of the mounting straps I could push the mats a little further forward. Also now I can easily remove them for cleaning. My thinking is with the pointy things on the bottom side of the mats they won't go anywhere, plus they're trapped on 3 sides. We'll see how they work out...
Edited by creekman
The pointy things go on the BOTTOM?? Well no wonder...
Yep, actually I had used another word that rhymes w/ "mits", but the site program did one of these ******, so pointy things was the next best. Maybe you have a better word?
