Porsche calls it PSM- Porsche Stability Management. I don't know if the 2004 986 has a PSM button to overide the system.
All 2005's (987's and now the 981) and newer have it.
Edited by White987S
As does the 2003 986.
Bill
Bill, that's good to know. What I am saying is that ALL 987's have PSM. I am just not sure (nor is the OP) that all 986's do too. My guess is that a 2004 986 does. I just don't know what year Porsche made the PSM standard on the 986.
My 2002 non "S" has PSM. It was a $4,000 option. The on/off button on my 986 is located first button to the right of the steering wheel and is labeled PSM.
Edited by gj3ny
  • 5 months later...
  • 3 years later...
1 hour ago, BoxsterBrothers said:
canPSM be added to a 2004 S ? from another car ?
Only with some difficulty and expense.  You would need to add the PSM control system, which uses the ABS network, and reprogram the DME to recognize it.  It would be a bit of work, and the cost would probably not be recovered at resale.
