Have an 08C2S with PASM and Sport Chrono package. As mentioned in a previous post, I am contemplating adding the OEM PSE to my car. In reading my owners manual on the PSE system, it is activated by pushing my sport mode button and does not have the separate twin exhaust button. Therefore I cannot use the PSE in "normal" mode. Can someone that has a car with my features tell me if I am right or wrong (or someone knowledgeable on these options).
Thanks in advance.
Can't help you completely, but my recommendation is to have the PSE active (in sport mode) at all times. Sounds great. Mine was connected to be active at all times. I like it this way.
Tony, it will help make the project easier, if you DIY. And/or make it less expensive if having the work done at the dealership or indy. Plus, you want that great sound at the lower speeds and RPM ranges.
Edited by White987S
