I hate myself to have to ask this question, but I can't get the MAF electrical connector off of the air filter body. Bentley's just says disconnect the connector so no help there. There seems to be a "button" on the back side, but no matter what I do the plug won't release. There's also a tab on each side of the plug, but no help there either. I wanted to take the filter body out of the car to clean and see what I can see behind the filter body.
Any help will be appreciated...
connector is tricky. easier to just remove the 2 torx screws and leave connector attached. lots of stuff on this, run a few searches.
The button on the back releases it. That said it can be a bear to activate. Sometimes it helps to push the connector "on" as you push the release to ease the pressure on the latch then pull it off.
Thanks for the info, I never could get the connector to come loose, so i just removed the air filter attaching screws and laid the lid over on the fender with proper protection of course. Just a point regarding the torx screws at the MAF electrical connector, you have to have a special torx that has a hole in the middle of the torx that will go over the center pin of the head of the screw/bolt. Next time I'll drill a hole on my lathe in the end of my torx wrench to do that.
It seems that all of the electrical connectors have a different release mechanism. Maybe some knowledgeable member could include all the connectors and how they release... I un-did another connector and the plastic keeper immediately broke. I'm guessing the plastic has become brittle from the engine heat. Porsche seems to have used a lot more plastic than my "84". Same for the tail light plastic attachment tabs, 3 of the 4 are cracked or broken. My car has 60,000 miles and hasn't been molested so these areas are indicative of a poor design. Just my 2 cents... However, I love the car, what a great driver...
