My remote locking/unlocking mechanism is becoming less and less sensitive. I have to hold the button down for a long time in order to lock/unlock the car, and the range is diminishing. Is this likely just a low battery in the key fob? What size battery does it take?
The battery is a round, lithium battery, No. 2032, about the size of a nickel, and available at most drug stores, Radio Shacks, etc.
Thank you, Kim!
You're welcome. You can go the TSBs on this site and find the one that details how to change the battery. I know .... that sounds like a joke .... but it shows which way to pry out the battery without your worrying that you're going to break the little tab; and, how to re-initialize the transmitter if it does not work after the change.
Thank you, Kim!
Thanks, again. You rock.
