Hi all, just purchased a 1999 convertible. I have noticed when manually raising the rear spoiler using the footwell switch it sounds like the motor continues to run after the spoiler is fully raised. Not sure if this is normal and will stop eventually? Thanks!
Motor runs, spoiler up, motor stops. If it continues to run you have a problem, but not sure what....maybe the switch is sticking.
