I've seen several posts indicating that their coolant tanks were leaking. Where do these leaks occur? At the hose connection, cap, or is it a cracked tank?
If you are dripping coolant than that will be 1 point off.
The plastic tank gets a hariline tank. Same issue with the Boxster.
If it is bad enough it will drip on the exhaust.
Jeff is right same issue with the 996. If the cap is leaking it is usually confined to the the lip area at the top of the tank and you notice the coolant level is low.
Replacing the cap takes about 30 seconds - replacing the tank takes about 1.5 hours.
My OPC broke my header tank when they replaced my 1st RMS, then had the gall to charge me for it. I presume when the dropped the gearbox, the engine shifted enough to cause the header tank to crack. When they showed it to me it looked like someone had taken to it with a hammer !
