Just for reference sake, in case anyone ever has the problem where the rear door refuses to open by pulling on the interior and exterior handle, a simple and temporary fix would be to apply quite a bit of pressure from the outside (as if trying to close the door shut) while at the same time pull on the exterior handle. After a few pulls on the exterior handle while applying a lot of pressure (enough to shake the truck) near the latch area will yield an open door.
Apparently this is an indication of a soon to fail lock mechanism. Another tell tale sign of this is when you need to pull more than once in case the car is unlocked or more than twice to unlock it.
Just another extremely annoying problem with this truck :cursing:
Hope it helps someone in the future.
