Looks like there might be a third cruise control retrofit in the works.
Look at your 1998 wiring diagrams and see if there is any difference with Ed's instructions. I'm sure the DME version changed but I do not know if the wiring changed. Then you will need a PST2 to turn it on. ;)
Thanks Jeff
It is a friend of mine who is interested in doing the retrofit on his C4S. I don't think it is a practical proposition to do it on my 98 C2. It seems like the C4S should be fairly straightforward provided stuff like the clutch switch is fitted. We need to start crawling under the dash.
If anyone has actually done it on a 996 it would be useful to hear from them - especially if it was a RoW model. P. Viby perhaps?
Jeff or Loren - Is the Motronic version the same on a C4S as an egas Boxster? (I think it is 7.8 on the later 986 Boxsters). Unfortunately I don't have the wiring diagrams for the later cars - unless anyone can oblige?
