My 2000 Boxster stopped dead last night. I have an OBD2 code P1576. The only thing I checked was serpentine belt and that is fine.
My mistake. It is P1579. Car went dead, all dash warning lights came on, no power steering, brake assist, etc.
That makes more sense.
P1579 Crankshaft Position Sensor – Not in Specified Range
Check for a loose or broken connector/wire first.
You will find the sensor on the flywheel housing - not to hard to change.
