Hey all,
So i have a Becker CR-220, and that DYN audio thing that sits in my lower shelf spot. My question is if i want to remove the DYN and put a shelf in OR move my A/C to the bottom spot; how do i bypass the DYNaudio amp thing, if i unplug it i get no sound from my radio.... any help would be awesome.
bump for help
Did you read the board Guideline/Rules that you agreed to when you registered here?
"No bumping. Do not bump posts. Bumping a post to "the top" does not help your topic get noticed. The volunteers who try to answer questions look for those without replies first - bumping defeats this. Bumped posts will be removed."
Are you asking about the DSP (Digital Sound Package)?
That was the only option other than the two amp options for MY1999.
The connector on the DSP is the only thing you should need to remove to take it out of the system.
