Hi When i shake the front wheels by hand on my 987 it induces a rattle like something is loose, any ideas, i have been feeling that the car is tramlining and wandering more than it should ?
If your lug nuts are not loose, you should check out your wheel bearings.
Do you get the same "rattle" on the left front and on the right front? What about the rear wheels.
It might also be the inner or outer track rod ends are worn, and there is some play in one or more. This seems to be getting increasingly common, and does give a tramlining effect.
