I have a 2010 997.2 C2S with pdk. My oil temperature moves up more than halfway the gauge when i am in stop and go traffic, and this is not yet the worst we have. Thinking of putting a center radiator to help in maintaining my oil temp for better engine life. Suncoast has a kit for the 997.1. Will this fit the 997.2? I understand that air ducts might be different as the bumpers for the series 1 and 2 are different. I am more concerned with the radiator hardware and accompanying mounting hardware and hoses. If they are the same then the 3rd rad of the 997.1 is mountable on the 997.2. And finally do our technical brothers recommend this mod? Really considering this option as the 2011s already have this as standard on the c2s pdk models.
Before making this modification, have you asked your Porsche dealership about this issue and whether or not it is normal. You still have warranty coverage so I'd go to them first. FWIW...
For everyones info yes it would fit. Most parts are the same. Modification of the air guides are what is neccessary for proper fit. The hoses, radiator mounting are all the same. My car was under warranty which prevented me from experimenting. After warranty i installed the kit and it was easy.
