I hooked up my Durametric cable on my 99 C2 cab the other day.
I checked the engine error codes section. Error P1531 - (Camshaft Adjustment Bank 1). This was not here the last two times I checked. Actually the only two times I checked.
No CEL light on the dash though.
I cleared the code and drove it another day. Same error on Durametric but again no CEL light.
Does the CEL light have a certain threshold (ie error code persisting for xx seconds or something) before lightning up indicating an issue? The car seems to idle and run up fine.
I googled and they said check the wiring harness to the solenoid & actuator. Where is this? I have the Bentley book but could not fine where it mentioned the Variocam actuator and electrical connector.
Any suggestions?
Jeff
P1531 Camshaft Adjustment, Bank 1 -- Actuator triggered, no active position.
Possible causes:
- Open circuit in triggering wire.
- Open circuit in B+ supply.
- Actuator faulty.
