Hello everyone,
I've noticed today what my Litronics won't raise with highbeam, and before they were running just fine. Here are some facts:
  • when I pull the headlight switch, the two halogen beams turn on. I remember that the low beams used to raise instead
  • the headlight switch seems to be running fine and i've never had any issues
  • every time I turn my car on, I can see both beams moving down and up for initial alignment, so I assume it's not a mechanical problem
  • I've replaced both Xenon bulbs a while back, but I don't think this can be an issue
  • I've also looked at this post: http://www.renntech.org/forums/topic/32240-litronics-wont-raise-with-highbeam-after-paint-job/page__hl__litronics but all my connectors seems to be in the right place
  • I have a Boxster S 2003, with factory installed Litronics
Thanks in advance for any guidance...
Julian-
As your topic appears to be a DIY question (rather than a DIY Tutorial), we have moved it to the appropriate forum.
This is an automatically generated reply.
  • 2 months later...
Well, it seems I've found my problem. As per 986wheelz's posting:
"The OEM Litronics install has a leveling sensor on the drivers side wheel suspension arm and also on the rear drivers side wheel suspension arm, both of these levelers connect to the litronic computer in your front trunk, the computer is on the passenger side of the trunk, the computer has a harness that connects to both Litronics. You may want to check the plugs on your Litronics to make sure they are properly connected and also check the computer to make sure the plugs are all properly plugged in"
http://www.renntech.org/forums/topic/31566-litronic-self-levelling-function-failure/
I fixed the sensor and my Litronics lights are working fine now. Thanks 986wheelz!
Julian-
