When I drop the top, only the two front windows can be raised; rear windows can't. The wind deflector would be more efficient if the rear windows could be raised since they would help to block air coming through the opening between the sides of the front seats and both ends of the deflector. The bmw 3 series convertible allows all windows to raise when top is dropped which makes its wind deflector more efficient. Anyone with similar issue been successful in overriding the system to allow the rear windows to be raised with the two front windows after top is dropped? Thanks. Walt M.
As your topic appears to be a DIY question (rather than a DIY Tutorial), we have moved it to the appropriate forum.
This is an automatically generated reply.
