Ok ....ready to tackle my top issue again. I was able to rebuild my back lid mechanics so that it works fine now. But I had to disconnect the hydraulic lines from the pump. Now when I put everything back together, filled the reservoir, the hydraulic motor starts but no top movement, Am I supposed to bled the air out of the lines? If so, can someone explain how I do that? Thanks
Just figured it out...... keep working the top switch up and down and refilling reservoir. Eventually it fills the lines and works
