Diagnosis Number 0203 and Fault Code C151 on my Durametric?
I hooked up my Durametric Cable to my "new to me" 2011 GT3. The only fault code that is listed is Diagnosis Number 0203, showing Current Fault Code C151. There is a brief comment that states "control unit communication", and "automatic transmission (drive) no signal communication. Anyone have any idea what this is? Is there a database of codes anywhere??
:welcome:
That code can not be correct - as GT3 does not have an automatic transmission.
Are you having any problems? or did you just hook-up the Durametric?
If you are not having a problem then it is likely safe to ignore the fault and have it checked next time you are at the dealer (under warranty).
