I changed the indicator stalk sometime ago and heard a squeaking sound coming from the clock spring a few days later. The new stalk works fine but now the airbag warning light stays on while driving. Any ideas what could be causing this? could it be related to the squeaky clock spring.
Any help is appreciated.
Once the airbag light is on - you will need Durametric, a PST2, or PIWIS tester to turn it off. Any of those testers can also tell you if there is still a fault in the airbag system.
