I noticed my '01 base ran a little high on the temp gauge today, on the right side of the 180 mark but the outside temp was in the mid to upper 70's.
After I let it sit for a couple of hours I opened the coolant cap to check & it was full of coolant but a few bubbles came up from the bottom of the tank.
Is this anything to be concerned about? Anything else I should check?
Couple things to check:
1) Clean out your front air intakes- may need to remove your bumper
2) Check the part number on your blue coolant cap. May want to purchase a new one.
3) Look for any coolant in your rear trunk. Look under the carpet.
4) Any noises with your water pump? May want to replace your water pump soon. And Serpt. Belt, thermostat, and do a coolant flush. Have you done any of this maintenance yet during your ownership?
Edited by White987S
1) Clean out your front air intakes- may need to remove your bumper (Did this about 2 months ago)
2) Check the part number on your blue coolant cap. May want to purchase a new one. (New one with the 04 suffix about 2 months ago)
3) Look for any coolant in your rear trunk. Look under the carpet. (Looked last night, it all looked dry)
4) Any noises with your water pump? May want to replace your water pump soon. And Serpt. Belt, thermostat, and do a coolant flush. Have you done any of this maintenance yet during your ownership? (No noises I can tell at this point. I was hoping to change the pump, Tstat & coolant in a few months when I install the center radiator. Serp belt was replaced in February, about 7k miles ago.)
I will keep a close eye on it & check on the belt & pulleys, see where that takes me.
Mine usually runs that temp all the time. Always has, unless its really hot then it runs a little hotter, especially in stop and go.
