Hello -
May have to replace a front 991 sport design wheel (damaged/cracked), I believe p/n is 991.362.161.32.
The hard part is it is a factory Exclusive black painted wheel. How do I go about ordering this? Is there
a different part number of suffix?....or color code for black?
More info,....part number could also be 991.362.161.32.88Z
That is the part number from the VIN info,....but I'm not sure if the .88Z part is the color code, from Porsche's description it means "bright chrome finish",...which it is certainly not as it is gloss black.
Thanks again,....
Spoke to my dealers parts department, but they were not overly helpful,....they simply quoted the .88Z code but come to find out this is just the
silver version and not the factory black painted version. Manged to find a copy of PET for the 991 but again there is only the 991.362.161.32.88Z
part number listed (silver). Looking at some of the other wheel part numbers (ones that can be painted black also) and there are no part numbers for
these either except for silver.
I'll probably have to find a pretty savy dealer parts guy that may have come across this before, but for now knowing how to order a replacement
factory black painted wheel seems to elude most out there. :(
You may consider to contact Suncoast Porsche parts in Sarasota, Florida, or Wheel Enhancement. They might be able to help you. Do you have a specific designated option code for black-painted wheel? If so, it should be included on your option list
Hello,
Because it is exclusive, you won't find the suffix in the parts program. Maybe in the tequipment section of PET. However, i have at home the Exclusive 911 personalisation catalogue. So, for wheels painted in black - the option code is XDA.
I could send you pictures from catalogue, but i'm new to forum, and don't know how to.
Hope this helps.
Hey Offroad aehsani is right, just call Suncoast. Only a Porsche dealer can order the wheel. They are great with this stuff. But if the wheel is not cracked, just bent, it can be safely straightened. Rule of thumb is if the defect is not easy to see until you spin the wheel it can be straightened. If the defect is painfully obvious just looking at the wheel it is trashed. There is a gray zone in the middle. A crack always trashes the wheel. I feel your pain. I have black wheels on my C4S. Back then they used crappy paint on the wheels so eventually I had to have them all powder coated. One was bent a little but now you would never know. There are companies that true wheels all over the place.
Another way some people deal with this is by getting a set of less expensive, easier to replace OZ wheels and put the originals in the attic for safe keeping. You can even get center lock wheels now.
Edited by Mijostyn
