I,ve been noticing a slight rumble in front wheels on hard left or right turns. Worse on drivers side than passenger.
Mine was the tie rods....Easy to do yourself. Change the inner and outer rods. Make sure you do both sides. You will need a tie rod wrench for the inner rod.
