I was wiring in my V1 and pulled a fuse when the car was running & put it back in. It was a 5 amp fuse in the drivers side fuse panel. No problem. Turn the car off and now it will not turn over. Gives "brake proportion warning" and "air suspension warning". Fuses are not blown???
Can anyone help. I did undo the negative terminal by the drivers passenger seat for 2 min. The warnings have disappeared, but it will still not start.
Sorry. 2005 Cayenne Turbo.
I am not exactly sure which fuse I pulled, but it was a 5 amp and could have been:
# 40 - instrument panel
# 53 - Heated rear window control etc
# 51 - Diagnosis, parking brake switch
# 49 - Servotronic, disengageable anti-roll bars
#48 - Auxiliary heater clock.
I did hook up the V1 to # 1 which is a 20 amp to the sockets. Now not hooked up
I do not know what possessed me to randomly pull a fuse. I am not really used to such a finicky system.
I undid the neg terminal by the drivers seat and checked every fuse. All are good.
I would make sure that these 2 below definitely have the proper fuse installed
Make sure the fuse isn't accidently installed in a blank spot
Verify that ground cable installation.
Cycle the ignition switch and try starting whilst depressing the brake pedal
Cheers n good luck
Thanks. A little more info. I tells me to press the brake pedal and the red brake light in the speedometer is flashing. It has been suggested that the brake pedal position sensor may have failed? I am pressing the brake pedal and the ground is properly attached. I will double check the fuses. One good thing is that it is at home. The bad is that the nearest Porsche shop is 180 miles away.
EleCTriCT. You are the man! I has fuse 40 in where it came out of 39 or something like that. I had just put the fuse back in one over from where I took it out. Next time I will pay more attention and take PICTURES. The simple is usually the answer.
Edited by mtnrat
