Would appreciate the part numbers for the above. Note that this is for the "S" model with the latest large bearing.
Thanks in advance.
Cheers.......
  • 5 months later...
Hi Loren,
To follow up, I now note that I also have an O-ring that goes behind the 22 mm center nut. Looks like pages 20-21 of the PET identifies two different O-rings:
7X2- 999 707 392 40, and,
18X2- 999 707 571 40.
Would you know which one I have?
Thanks.
That will depend on your intermediate shaft - and MY2006 was a change over year.
Since these are only about MSRP $2 each I would buy both and then use the one that is the correct size (based on the old one).
