I have a 2004 C4S and need to replace the Bank 2 O2 sensor after cat; is the bank 2 the passenger side?
I have attached a pic under the car on passenger side looking toward the rear bumper; there are two sensors there; are those actually for bank 1?
Would the bank 2 after cat actually be on the drivers side?
So from the passenger side I follow the header a coupe feet into the cat; there is a sensor with blue wires before cat; there is another sensor with shorter gray wires that screws into the round end of the cat; the pipe then goes over to the driver side and goes up into a muffler and then comes back down to exchasut tip/exit on driver side.
Sound correct?
Thanks Loren; installed it and disconnected the negative terminal and reconnected oit and check engine gone; seems to be running fine; thanks for the help.
