Hi Loren,
Is there any information available for relocating the Tail Lift "TIP" switch (996 613 155 00) from the fuse panel to the center console? And, is there a part number for the connector and terminals that plug into the switch assembly?
Best Regards,
John
I think Jeff (Tool Pants) has the part numbers for the connectors but.... most of these connectors are standard size "Radio Shack" parts. I would also use the same gauge wire (as what is on the current switch) from the fuse panel to the dash and make sure your splices are good.
