I have ordered several sets of rear sway bar bushings but they all measure 18mm, a pair of green dot and a pair of blue dot they are all 18mm.....even though per the BLUE dot on them they should be for the 21mm bar. The problem is that if expanded to fit the 21mm bar then the bushing will not seat properly in the sway bar mount bracket under the car. .....What is it with the bushings .
George
87 Carrera with stock 21 mm rear bar
