Preliminary work
Release the relay carrier in the plenum chamber E-box and lay it aside. Refer to 97 90 19 Removing and
installing relay carrier, plenum chamber E-box - as of MY 2003 (All Models) .
I need to replace my alarn siren and I'm looking for instructions on removing the fuse box above it.
Loren you ROCK! This was exactly what I needed! People may need it to replace the darn alarm siren that keeps failing due to Porche's poor design on the horns due to water penetration. Again, you just saved me $300 in labor!
  • 7 months later...
I'm also looking to replace the siren, my workshop manual explains how to remove the siren but not how to remove the fuse box (section: 97 90 19 Removing andinstalling relay carrier).
Can someone explain how you remove the fuse box/relay carrier.
Thx, Stu
Loren, I need to replace mine as well, or at least clean up the connectors, can you send me a PM as well please ? Thank you !
Replace what siren? relay carrier? please be more specific. Thanks.
Thank you very much Loren, highly appreciated !
The only part I don't know is "9790191 Removing and installing the relay carrier E−box plenum panel "
I sent you another PM.
