Hi guys,
My 04CTT PCM2.0 (with fiber optic BOSE) decided to stop working again. traced to board level, found a shorted capacitor and a filter transformer. still not working.
I would like to get a PCM2.1 unit since 2.0 ones are hard to find now. and this is the second 2.0 that I replaced. I doubt there might be some design issue with 2.0 ones.
only question here:
from my understanding, the GPS function would not work since 2.1 is DVD rather than 2.0CD
but would everything else, eg. audio. trip computer work? I do not really care about the GPS function but I want my radio back.
thanks guys!
Audio will work, I think someone has done this
Errors will occur tho if DVD Drive is not present, can be annoying
I believe my CS 2005 is PCM2.1. I know the 2004 wasn't DVD and PCM shares the CD slot with audio & map cd. 2005 started to have DVD map and a separate DVD drive is under the front passenger seat.
thanks guys for the response.
I called the local dealer today. the parts guy told me I will have to install the DVD drive under the passenger seat and lots of wiring. and will take a lot of time to do it.
I know people did that themself and wired the whole thing and it worked.
to me, I just need the audio part working. and I do not want to do any extensive rewiring.
also he mentioned that all the interfaces are different, which I highly doubted. the only visual difference I noticed between photoes of 2.0 and 2.1 are just the GPS module at the bottom. I mean why would Porsche design the whole thing again just to use a DVD drive instead of CD?
I will try it anyways. will keep you guys updated. should be an interesting topic.
Edited by royxaxa
