On the way home last night my nightmare started. In lower revs felt a shutter from under the car next thing you know grinding.
Then raising the clutch a bunch of grinding clunks and bangs and finally won't move Dropped off at PORSCHE :-(
HIGH MILEAGE
99,600 S 997.1
Any rough ideas on what this might be and cost to rebuild at a local lower cost PORSCHE shop.
I cannot afford to go NEW and yes I am out of warranty.
:censored:
Sounds to me like a disintegrated clutch rather than a trani. If in fact it is the trani or transaxle, then first explore buying used from a dismantler. I would start with those advertising in Panorama and Excellence magazines. Ask around and get yourself a good independent Porsche shop once the dealer tells you the likely issues. Good luck and let us know how you make out.
