My car sat for about two months and battery went dead. Charged my battery -- put up my cab top - now the top latches and unlatches and back windows will not go up. Front windows work fine. Do I need to have my top recalibrated?
Appreciate any help.
Chuck
my 99 cab engine is out and car has been sitting for 5 months,have on a trickle charger but battery got a little weak (playing radio).
Now, when I turn on key I get the "rear spoiler is up" symbol in dash( it is down). Press the top down button and windows drop, top unlatches, rear top skin lifts fully and then ...nothing, top malfunction starts to flash. micro switch or will weak battery or both cause this ? ideas ?
thanks
thanks
A weak battery will cause all kinds of anomalies.
If the battery is over 4 years old - replace it. You'll be saving yourself from being stranded sometime soon.
If the battery is newer then have it both load tested (out of the car) and have the specific gravity of each cell tested. Replace it if these do not pass with flying colors.
I had exactly this problem - it was the plastic cover on the centre latch which had broken and come loose therefore not making the switch properly.Cheap fix - just glue the plastic cover back on.
