Just recently the Check Engine Light came on by 2001 Boxster S. I plugged in my Durametric reader and the following (3) codes appeared……….
P0430 Porsche code 45 Cat conversion bank 2 / exceeds limit value
P1411 Porsche code 208 Secondary air injection system Cyl (4-6)
P0410 Porsche code 80 Secondary air injection system Cyl (1-3)
Can anyone tell me what failure would cause these codes to appear?
I suspect O2 sensors ????
The following are the O2 sensor resistance readings………
Bank 1 ahead of CC: 128 Bank 1 behind CC: 384
Bank 2 ahead of CC: 64 Bank 2 behind CC: 265
Can anyone tell me what the baseline reading should be?
None of these codes point to a an O2 sensor issue.
You need to fix the secondary air pump - it likely not running (hence the P0410 and P1411).
Check the fuse, relay and wiring (could even be un-plugged).
Then clear the codes and see if any come back.
Loren, thank you for the feed back information.
With my Durametric, I believe triggered the secondary air pump (sounds like a vacuum cleaner) with the Durametric drive links. Does that indicate the fuse and relay are functioning?
I have cleared the codes and driven the car two different 10 mike trips and the codes (so far) have not returned.
