Here is a problem I haven't read much about on this forum. 2004 CTT (of course!) with 122,000 miles. Had the steering noises especially when turning left and binding in the steering wheel. Thought it might be the stepper and was ready to replace that when, one morning after a 3 hour drive the day before, the steering system made some loud rubbing sounds when turning the wheel either direction still parked in the garage. Looked in the pump reservoir and didn't see ANY fluid. Bought some 11s, topped it up, and no more noises! So I am getting the o-rings replaced. You can see the big port on the bottom side of the pump by looking up from under the vehicle at the front of the engine on the driver's side. Mine had leaked a lot so I had to degrease first to see where it was leaking from.
Tim in Ft Worth
