Attached please find a picture of the back of my headlight. A couple of questions, per the picture:
A - Is this one of the bolts being refered to as coming loose sometimes? Is the other bolt directly on the other side?
B - Has anyone ever broken this connector? I broke mine but ended up using a wire tie to hold the bundle in place.
B - What is the part number / cost for this bracket piece?
C - Is this connector ever the problem or is it always D?
2006 S Titanium Edition (i.e. V8)
Tom
post-62558-0-07846100-1347729821_thumb.j
thanks for the cost estimate but I am really looking to know which connector gives the biggest problems. I presume it is 'D' but wanted confirmation...
my problem was from the connector to the headlight assembly. over time with viberation the whole headlight become loose. i changed the plate and it solved the problem.
B in the photo is not critical i think. D is the spot that gives up over time.
Edited by royxaxa
Thanks. I've spent about $2,800 on repairs over the last 6 -8 weeks so I was expecting my problem to be much worse. Turned out to be just a blown cornering bulb on the left side that was preventing either side from working. Fixed today for $12.95 (set of two).
Thank goodness for small favors.
