I have to push extra hard on the clutch peddle to get the starter to engage the engine to start the car. Is there a way to adjust the clutch safety switch so it dosen't take 3 or 4 trys to start the engine?
You can replace the switch or jump it with a wire to override the switch. If you jump it, you'll need to be careful to always start car with clutch in or take the car out of gear.
