ok guys.. a little help here. My case is at LN engineering for new cylinders and IMS retro . They are sending me new JE pistons while the work is being done and are suggesting that I have the crank, rods, new pistons, flywheel, pressure plate,clutch..... the whole enchilda dynamically balanced. I am using the same crank, rods, with new ARP bolts( and dual mass flywheel)
DO I NEED TO BALANCE THE ASSEMBLY OR IS IT OK?
How much could I expect to pay? anyone in washington DC area anyone would reccomend ?
No, it is not "OK" as delivered, everything needs to be dynamically balanced as the pistons alone will throw everything out of balance, plus the factory balance ain't all that swift to begin with...........
Either Dave at Exclusive Car Care in Manassas or Charlie Murphy at Intersport in Tyson's . I have used both for years, and they are both wizards.
