Sorry if this sounds amateur but how do you remove the trim to get into the handbrake cable adjustment? I need to tighten it up slightly but don't want to damage the trim. It's a 1998 c2. Thanks in advance.
Trivial, open the center console container and lift the rubber bottom pad. You'll find one screw on the rear end of it. Uncrew it, lift the plastic plate it secures and voila.
