Does anyone know if the Sportechno wheels which come with the 17mm spacers, will accept the older style locking lug nuts from the 930-993 series?
The wheels are are bolted on the spacers with the old style19mm aluminum lug nuts.
The 996 bolt type wheel studs-along with the locking lug-are used to bolt the 17mm spacer to the wheel hub, so the locking lug is not protecting anything but the spacer.
Part number 99336105700 (?) seems to fit most 930-993 models. Could these be used?
BD
