I need some help on how to adjust the up travel (close) on the drivers window, is traveling about .300" more than the passenger side and its making a clicking noise once it reaches its travel as compare to the other door. i beleive there are some kind of adjustment on the bottom of the door but i would like to confirmed. car is a 2007 997.1 S
Thank you all in advance
ER
Have you tried this:
Storing end position of the windows
If the battery is disconnected and reconnected, the
windows will not be raised automatically when the
door is closed.
1. Close the windows with the rocker switch once.
2. Press the rocker switch upwards again to
store the end position of the windows in the
control unit.
Edited by alpine-al
door is closed.
control unit.
No the issue i have is a little over travel in the close position and i need to adjust the end travel / stop limit i know there are adjustments torqs in the bottom of the door but i need some guidance as to how to proceed to adjust
Loren if you can please give me some guidance
tthanks again to all
ER
It is more likely a bad regulator than an adjustment.
Either way the inside door panel likely needs to come off for inspection or adjustment.
Thanks Loren
today i removed the plastic cover on the bottom of door and with the windown down you can see the torque screw adjustment my window operates OK the issue is compare to other door the travel going up close pos is a bit to much can this adjustment take care of .200 to .500 inch?
thanks
ER
