P1511 Throttle jacking unit - abortion of test due to negative influence on ambient condition
Possible fault cause
- Starting the vehicle during adaptation after replacement of throttle part
Diagnosis/troubleshooting
Perform adaptation:
Switch on the ignition
- Wait one minute Do not press the accelerator
- Switch off the ignition for at least 10 seconds
- Read out the fault memory
Perform adaptation:
Loren to the rescue as always. Thanks!
