Hi all,
I have been trying to find a DIY guide to partially drop the ingine of my 997 C2 (2005) as I want to give the engine a good clean from the inside.
I am sure I saw once a guide with good photos but could not find it again.
Is there anyone who could point me to such a guide?
thanks
2005 Carrera 997.1 Cabrio Tiptronic
Hi all,
reading some material around I found the following:
1. put the vehicle on jack stands
2. remove airbox
3. using an hydraulic jack, raise a "platform" to sustain the engine from the bottom
4. unscrew the engine motor mounts and remove them
Now I should be able to slowly lower the jack (item 3 above) and the engine should drop about few inches, right?
Here are my doubts:
a. How would I know how much I can lower the engine without causing damage? I mean, what happens if I lower it too much? Will I break something?
Or does it stop dropping?
b. a part from the airbox, is there any other item I should remove (hose, pipe, electrical connectors) to avoid breaking it because of stretching while the engine is partially dropped?
thanks
