2003 ctt
hi guys my blue tooth finally arrived and now i need to install it as i said in my previous thread the denison 500 was installed next to the cd changer in the rear so i need to route the microphone to the drivers front i think next to the sunroof and interior lights ,or maybe on the right side of the windsceen blind im not sure yet but im guessing i need to pull the headliner somewhat or the side pillers where the airbags are,any help or insight ,i would be gratefull...
I can't say for certain, but... I'm betting that you'll need an extension microphone cable to reach to the front windshield area from the CD changer location (I mounted my GW500/BTA1500 behind the dash)..
I'd be inclined to run it under the carpeting along the outside edge on the passengers side rather then risk breaking any of the clips holding the headliner in place. You can run it up the interior of the A pillar to get it up to the front/top of the windshield. If you see my thread on fixing water leaks in the interior, there are some photos showing how it might be routed (the photos are of the sunroof drain, but if you look closely, you'll see my microphone cable tie-wrapped and routed up near the drain plumbing.)
You also should exercise care in not routing it over the airbags, since if one is triggered, you don't want it restrained by a piece of wire over it.
