Hi.
Does anyone know if there is anything i can do to fix my problem
i've got these codes and the car has only 65000km and is an 2004
i understand that the problem is with the cat conversion banks 1,2, could it be because i filled it up
with unledded 95 instead of 98 ( i've only done that twice .....) ?
is there any major difference on 95 or 98....?
is there anything i can do instead of changing the cat's ?
/ Toby from sweden
P0420 TWC Conversion, Bank 1 - Above Limit
P0430 TWC Conversion, Bank 2 - Above Limit
Possible fault cause
- Oxygen sensor ahead of and after TWC exchanged
- Valve lift fault
- Aged oxygen sensor after TWC
- TWC faulty
HI Loren !
Thank you for your answer, i've talked today with porsche center and the guy there told me that i could be the low octan fuel ( 95 ) that i drove on,
now i have erased the fault in the log and filled up the gas with shell V-power instead.
i have been out for a test run for an hour now and now sign of fail indication.
could it been that the oxygen sensor only responded to the low mix of fuel ?
do ypu thing that i should put one of those redline fuel cleaners in the tank to really clean the oxygen sensors ?
by the way , the gt3 only has one O2 sensor, what i could see.
looking forward for your response.
Thanks !
Toby
Yes, it could be the low octane fuel. Always put in the Porsche specified octane.
I would just use the higher grade fuel - certainly by the next fill up your fuel should be all the higher octane (not a mix).
